TruckCo
- Feb 3, 2023
- MA
- Jay
- C10
I recently purchased a 87 C10 with dual tanks. Truck had a frame off restoration a few years ago and has an edelbrock Multi port fuel injection system. The owner said both tanks work. I had a few questions about the dual tanks regarding this matter.
When the switch is on LH and I turn the key on the fuel gauge registers, and I can hear a "strong" initial pump sound coming from the tank I believe for a few seconds then shuts off. When I switch the selector over with the truck off but key on, I don't hear anything actuate, and the fuel gauge stays where its at.
If I shut the key off, switch to RH and turn the key on, the gas gauge will spike past full, and I will hear a momentary "brr" , different sound of the pump (may be weaker or aftermarket) I assume these trucks have separate fuel tanks.
Its winter out so I haven't driven it yet but is this all normal and can anyone point me in the right direction if something is wrong in terms of the gauge or the selectors not working or does this sound normal? I assume if one tanks not working the truck will die instantly unlike a carburetor which kinda scares me cus at least you have bowl float fuel to safely pull over etc.
Also, I thought these trucks had seperate fuel pumps inside each tank. When I laid underneath, there is a fuel filter and a seperate pump next to eachother on the passengar side frame rail? So would this do both tanks as well?
I am a little lost. Any help would be appreciated.
