Dually Wheel Fitment Help
Auburn, Washington
Unfortunately that is the only way to get these so I do have polished inners as well. Nothing like not seeing your money haha
I was just gonna say you're a real baller!
Auburn, Washington
As for getting it on the road it is a flip kit drop, so it would have to be one heck of a spacer. I'm actually getting my stock wheels back and just going to slap those on until I can figure everything out.
If you could slap a cheap set of helper springs in it (presume you removed some leafs or a flip kit would be more than 8" on a 1 ton), to crank'er up just a little.
Can you roll the wheel well lip without messing up the paint? That would help, but I no good at bodywork.
Or **** can your rear wheels and have em make some super singles!
Now lets see a pic of what's parked next to it!
And have to post your color sand/cut/polish recipe. That paint job is perfect!
Craig 85
Nashville, TN
454/TH-400/NP205
Here's some reference info for you. I've posted this picture on the forum before (photo #1), its one I grabbed off the internet.
Form what I read, this is a chassis cab truck with a short bed installed. It is running standard 16" dually wheels, that just barely stick out from stand fenders. The inner tire is close to the spring with this set up (see photo #2 & 3). FYI the chassis cab rear end is a 14 Bolt, not a Dana 70 like you probably have. Photo #4 is my K30 SRW with a 14 bolt, but it has 13x3.5" drums like a dually does. My drums are spaced a little further out than the Chassis cab version.
FYI 3/4 ton 14 bolts are the same as mine with a couple of differences. Drums are only 3" wide, the spring hangers are farther apart and the shock mounts are on opposite sides of the axle.
Last photo is from AMD Direct. They make 4" wider inner wheel tubs, but of course they are out of stock. They would work if you used one of the narrowed axles.
*Disclaimer* I'm not at all familiar with how these trucks are normally done with large dually rims...
I don't believe that a cab&chassis rear axle is a good option here. That will narrow up the track width way too much. Spacers would be needed, which I guess is why it works for most folks because they use an 8-10 lug adapter.
If you run a SRW axle, that will put the track width somewhere close to what is needed? I don't recall the difference compared to the D70 dually axle.
Another option may be a 14bolt full float axle from a G30 van. Iirc, they are a couple inches wider than a SRW truck axle and probably just a smidgen narrower than a full width dually axle.
Also, I must say that I really like the concept of these wheels. Looks like 10 lug, no adapters, wider fronts, polished inners.... I just dig it.
Android04
Louisville, KY
Andrew
C30
400 SBC
Both are just painted, no wet sand or buff! OrangeSlice is Prowler Orange and Willy is the original color. Cab is original other then rockers and floor pans. All other metal is replaced other then the hood and then all painted to match the patina look
Android04
Louisville, KY
Andrew
C30
400 SBC
I talked with a few guys yesterday and may just either narrow the rear and or try and find a 3/4 ton rear end.
I greatly appreciate everyone’s knowledge
Android04
Louisville, KY
Andrew
C30
400 SBC
thank you for the info!
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Why not just pull a little of the drop back out of it? Those wheels would probably fit fine at stock height. Would losing an inch of drop be all that bad for the look you want? Seems simpler than swapping axles etc etc.
Don't bother with a 3/4 ton rear axle unless it's free. A rear from a 1 ton (single rear wheel) truck will bolt right in without having to relocate the spring perches and shock mounts.
newbie17
tx
bob
R30
5.7 tbi
No offense, but---YUK!!
Android04
Louisville, KY
Andrew
C30
400 SBC
If you have to say "No Offense" then why post? I'll never understand that mentality.
Best thing about our hobby is we build them for ourselves not for everyone else.
That's exactly what I did. I got a SRW and I'm swapping on DRW C&C Hubs this week it should be on the road. Thanks for all the help everyone.
Big Chip
Michigan
Kevin
C35
...says the guy with the ****** bag yellow turd. A little advice: don't be a dick and things will go a lot easier for you.
Do you even need the DRW hubs? Still not enough clearance with the SRW hubs? Take any pictures showing the fitment differences?
Man, we can't even say *********?
Hey! .....I like yellow trucks too :rofl:
GorillaHumper
