Dual fuel gas/pane
roving4s
America
xxxx
Any of you guys/ladies run dual fuel, I've ran pane on my yota's. But thought about duel fuel for the k10. Gas for cruising around on the road and pane for trail. Just not to many places around here to have the tanks filled to go full pane on the street.
jux
PA
Z
Kind of.
A year ago i bought a wrecked 86 c10 that was identical to the 86 I drive. I needed the 350 in it for an engine swap I was doing to ditch the underpowered 4.3 that I had in mine.
I noticed that it had been set up for propane, but now is running gas only and is running well.
Other than saying it is do-able, I have no other helpful info. Good luck.
Boone83K10
Boone, NC
Benjamin
Dual tanks are pretty easy, I have them. But I'm not sure how you would use the switching valve between gas and propane. Isn't propane under a higher pressure, because the switching valve is rated for 65lb of pressure I believe.
Sent from my SCH-I535 using Tapatalk
roving4s
America
xxxx
Last time I ran pane I wasn't using forktruck kits. I used a gotpropane kit for a 22r.
Then again my 350 doesn't have a whole lot of sensors and useless junk since it's carb. Just to keep it from cutting out on hill, the only carb I've found . Is the holly truck avenger but that's $700-900. with pane I could eliminate that all together and get rid of the forever cranking on cold mornings.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
I know they make a dual fuel kit. I've had a few trucks that were dual fuel over the years. Shame propane isn't easier for most of us to get, It's defanatly the way to go anymore. I've seen a few of the dual fuel kits on ebay, and one company on there sells kits for everything you can imagine. there used to be a truck dealer in a small town not to far from me that delt in used propane company fleet trucks. I've bought several trucks off him but last time I was by there his lot was bare. Shame because for $1k or less usually bought a nice truck there
roving4s
America
xxxx
I'd love for my k10 to run like the ups trucks.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Some of the kits for new vehicles are very slick. Will start the engine on gasoline and then switch over to gaseous fuel. Will also automatically switch back to gasoline when the gaseous fuel runs out. Not sure of the cost though.
zbbfoo
