Drop Height Fiasco
Devo105
Louisiana
Devin
Hello all! First time poster, long time follower. I have a 1985 C-15 that I decided to lower one step at a time. From factory ride height, I decided to install a set of 2 inch drop spindles to level the truck. This was the first issue. The spindles got close, but didn’t lower the rear a full 2 inches. But it got me within a half inch of the front so I was happy enough. Then I decided to grab a set of 2 inch drop coils and a set of 2 inch drop hangers. Both went in with no issues, but when I removed the jack stands I noticed that the front was about an inch and a half lower than the back. The truck is also about a half inch higher on the passenger side. Below are exact measurements from the ground to the wheel wells:
Front left 28 3/8 Front right 28 7/8
Back left 29 7/8 Back right 30 5/8
I am attaching pics of the hangers and shackles to show correct installation. I did notch the bed support and have plenty of clearance there.
Pictures 1-4 are of the new shackles and hangers.
Picture 5 is of the current stance from the side.
Please help!! She’s too sexy to be this unlevel!!
Traucht
Tennessee
A
I like the rake!
That looks like more than 2 inches in the front. Are you sure you have the right springs?
What do you want next? Lower back or raise front?
Devo105
Louisiana
Devin
Thanks man! I ordered 2 inch drop springs from LMC, and they were both 2 inches shorter than the stock coils. My goal is to get as close to level as possible. I’m probably gonna have to bring the front up a bit to avoid doing an axle flip. A bigger concern to me is the difference between the driver and passenger sides.
86c10twotone
MD
Roy
Why not just do the flip kit ?
86c10twotone
MD
Roy
The left and right rear difference issue is most likely your shocks . I had a similar issue replaced the shocks and it settled
yepyep
the moon
joe
v20
350 tbi
god your truck has me drooling ive got a K20 im restoring was thinking about doing red and white, my old c10 was dark blue and silver very nice also but damn nice square body
and sorry not useful at all i know
Devo105
Louisiana
Devin
i honestly like the look of a 2/4 best! And if I did flip the axle, then I’d have to undo the shackle and hanger drop that I already invested in.
I did forget to mention that I replaced all 4 shocks. Good thought though, I appreciate it!
Thanks dude, it’s been a fun project! If the interior hadn’t already been red, I would’ve gone with the blue/silver scheme!
I'm a little confused. You bought front spindles first? That wouldn't change the rear at all. So then you got drop hangers for the rear and 2" drop coils for the front?
Each time, you've gone down further in the front than the rear. At this point, your options will be to put the stock front springs back in or do a flip kit in the rear and do away with the drop shackles.
How low are you looking to go? My blue truck is roughly 5-5.5/6" with spindles/springs up front and a flip kit in the rear. My buddy's red and white one is roughly 5/7 with drop lower control arms, flip kit and a block in the back.
Also, my truck sat lower on the driver's side as well (moved the battery to that side when I LS swapped it, fuel tank and me are over there too. I don't have dual tanks). I just trimmed the pass side front coil a little at a time until the truck sat how I wanted. I'm within about 1/4" on each side now, not noticeable
Devo105
Louisiana
Devin
I apologize, that was a typo. I started with 2” SHACKES, not spindles.
Devo105
Louisiana
Devin
Right on, i dont mind doing some coil trimming! How can I even the back out though?!
Start with the front and that will even out the back as well, it did on mine. If you get the front close and the rear is still out alot, you may have a twist in the frame. If your shackles have multiple holes, you can put one side in a different hole than the other to correct the lean. But start with the front first and see what happens
Devo105
Louisiana
Devin
Thanks again man! I report back with the results!
Cantrell299
