Drop Height Fiasco
Devo105
Louisiana
Devin
Before you do any trimming on the coils, be sure they are in the spring pocket correctly. If it is not seated it can cause the height issue.
Ahh yea, that’s good advice! Thanks man! I’ll tear it all back down this weekend and let y’all know!
cootertrucks
St Peters, MO
Steve
R10
I would look at getting some name brand coils from Bell Tech or McGauphys. I have been using LMC for over 20 years and trust most everything they sell other than lowering suspension. Odds are they used some cheap OEM that did not mimic the correct spring rates so your 2" coils are probably actually giving you 3" of drop. If you have the money, I think you are better served to get 2" spindles and run your stock coils. Spindles always align better/easier than coil drops.
Devo105
Louisiana
Devin
Oh wow, that would suck. Ok, thanks for the advice!!
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
As has been said front springs check they are in the pocket , easy to get it wrong, secondly rear axle flip and notch the chassis is a quantum change to these trucks IMHO.
good luck
Devo105
Louisiana
Devin
UPDATE!!
cootertrucks nailed it! Cheap 2” drop coils from LMC are not built to factory spec and couldn’t handle the weight. Slapped a pair of Belltech’s on her, and she sits perfect! Thank you all again for the input. Top pic is LMC coils, bottom is Belltech’s.
Scott91370
Burleson, Tx
Scott
Sierra1500
Quick question. The trim down the side - is that the factory style or is it thinner? Looks thinner until I see it near the taillight then it looks factory.
THANKS!
Truck looks good!
Auburn, Washington
Truck looks good!
That’s OE width trim.
ReefkoiC10
Colorado Springs
LS3
You get what you pay for especially these days! Ive pulled a bunch of low cost stuff off my truck and replaced with good pieces mostly stuff made in the USA and it actually fits and works so much better every time Im so happy with the higher cost stuff.
JoeyPepperoni
