drive shaft hits crossmember
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
You're dropping the crossmember, not the t/c itself. And you don't need anything that fancy, the bits that RC supplied with my kit were simply 4 pieces of thick-walled pipe measuring 3/4" o.d. X 1" tall. Placed between the crossmember and the frame with longer bolts, they provide more driveline clearance.
McCSquare
Champaign, IL
Doesn't that put a lot more stress on the bolts and the holes in the frame? Normally you have the whole edge/face of the crossmember contacting the frame to distribute force.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Maybe, but I've been running it that way for ten years without issue and my truck works hard. Lots of steep offroad use carrying more than 3000 lbs. If it were going to fail it should of by now.
I've seen some other kits come with a solid piece of steel instead of individual bits, you can use those if you're not sure about it.
McCSquare
Champaign, IL
Glad to hear they have held up. Keyboard engineering isn't as important as long term field testing. The kit that RC currently sells looks like a composite material, with a few holes in it. Do you know who else sells these kits?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
mlcd
