Down 1 Cylinder
Ronno6
South Mississippi
Ron
It has been a long time since I have had to do any engine diagnosis...
I built my 355 out of a 95 pickup.
It has sat for some time..like 2 years.
Running like crap......carb dirty, but switching to Fitech RBI.
The #2 cylinder not firing, or maybe it is.
Header pipe only lukewarm when others are quite hot.
Spark plug is black, but dry.
I suspect they all are black; running rich...
I swapped in another plug wire to no avail.
Gonna try a new plug when they arrive.
Compression about 140# or so, so no valve problem.
Where should i be looking??
Rickf
Grafton NH
1974, 1954 & a 1937
Are you using a stock type HEI? Have you looked inside the cap for something odd/out of place like a messed up post?
Swap plug and wire between 2 cylinders,see if the problem follows the move.
  • Like
Reactions: WFO
Ronno6
South Mississippi
Ron
Upon further investigation, header pipes for cyls. 2.6.and 7 are very cool after a 30 second run...
Dunno what's up.......... Carb is a mess......will re-evaluate once I get the Fitech up and running.
cousblake11
