Door won't open
flainn
Los Lunas, NM USA
Matthew
K2500
5.7L V8
Hi guys, I'm going through the basic stuff on my new Burb. One of the big things is that since I got it home, the front passenger door doesn't want to open. It seems to be unlocked (the thingy pops up, anyway) but it won't open from the outside or the inside -- acts just like it's locked. Key doesn't do anything, and neither do the power locks. It just seems stuck.
Wondering how I get it open and make sure it opens when I want it to.
Mine did this for a while, the latch needed lubed. The lock would basically get jammed up a bit and the knob would not come all the way up. Try pulling the inside handle quickly and repeatedly, sort of letting it snap back to it's stop. Do that maybe 10 or 15 times and then try pulling the lock knob up the rest of the way.
flainn
Los Lunas, NM USA
Matthew
K2500
5.7L V8
Will do! Thanks man. If I can get it open, I'm going to lube it good. Heh, heh.
flainn
Los Lunas, NM USA
Matthew
K2500
5.7L V8
That's the place ... stay tuned for the further adventures of Saul Goodman.
flainn
Los Lunas, NM USA
Matthew
K2500
5.7L V8
I did just what you said, and it worked great! Got the door opened and used white lithium grease on the hasp, and now it's working perfect.
I took the opportunity to grease the hasps and hinges on all the doors, too.
Thanks!
I ended up pulling the door panel and lubing the latch from the inside with penetrating oil, that way I knew everything was freed up. Glad it worked!
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
It worked for me!!!
Thanks!!!
Love this app
Such an amazing tool for a newbie like me
Neal Lind
Grande Prairie
Neal
V3500 4x4
Thanks for the post. Tried snapping it back a bunch of times and poof! Door opened
jimlayhee
