Door Weatherstrip Install
dhenderz
Michigan
Dennis
I purchased a complete weatherstrip set from Precision for the 77 K10 restoration. There are 2 of the door weatherstrip DWB 1111 73 in the kit. According to their website this seal is supposed to go on the top edge of the door with the tall portion of the profile facing the cab. But there is no attachment method on the seal or the door. How/where exactly does this seal go? Am I supposed to glue this on with weatherstrip adhesive? How do I know where to locate it on the door? Thanks.
Big Chip
Michigan
Kevin
C35
Glue or double sided tape is my guess. Mine just looked like the 3M 1300 (I think that’s the number).
yevgenievich
Place
Name
Year
Model
Size
Originals actually had screw on two ends and the middle glued. Helps with wind noise. Weatherstripping adhesive would work, it sticks quickly as well.
dhenderz
Michigan
Dennis
Thanks for the info. Approx where do the weatherstrip start/stop on the door?
80BrownK10
Greenwood, SC
Nate
It glues on. The factory has screw attachment points on each end but the rest is glued. I glued mine. I actually got the profile wrong on one door. Oh well it's 90° off. Still seems to work.
Craig 85
Nashville, TN
454/TH-400/NP205
Here's how the OEM style mount. This was a discussion on another thread a while back. I believe mine have a different shape than the Precision style without the screw in ends.
Big Chip
Michigan
Kevin
C35
1-1/2” above the bolt for the door handle and you can see where the front ends. These are original 1978 doors from a suburban and there are no screws or tabs on the rubber.
My 1980 doors have the screw on rubber. I had a 74 that had it only glued on.
Phoenix
Ca
Jeff
Looking into getting new weather stripping for my truck currently, does this stuff HAVE to be ordered from a place like LMC, or is weather stripping pretty universal? LMC wants $80 for a full kit, but universal stuff is 10x cheaper...
80BrownK10
Greenwood, SC
Nate
I got it off eBay. It was like $20 or so for both doors. It was glue on.
80BrownK10
Greenwood, SC
Nate
I supplied the 3m weather strip glue
80BrownK10
Greenwood, SC
Nate
Why glue it? It fits in there pretty tight. On the pinch weld seam.
@80BrownK10
Im talking about the top of the door weather strip.
Back to the title of the thread the cab weather strip, I got that in a kit off eBay as well that had all the door rubber. I did not glue the cab weatherstrip/seal in.
eskimomann209
Modesto
Marcus
I feel like this is a totally different thread than what I first read. I was sober when I read this I think?
I’m going to check myself into the Psyc ward. Have a good one everyone.
Rashad Baker
The Dirty South
Rashad
V1500 Suburban
Sorry to revive an old thread but I just brought the front door seals (with the screw holes) for my suburban to help with wind noise and I am confused on what way these should go on. Craig, your picture shows these going on one way and LMC Truck shows these going on with the ends reversed (picture below). Can anyone offer clarification on this for me?
zapattack
