Door Strikers
And that's very important !!! At least the white matches my K1500. :roflbow:
:waytogo:
And if there is blue that should keep Old77 from complaining. :Moon:
Christian Nelson
Wisconsin
Christian
K15
You can get white blue and red for any size..
http://www.pexsupply.com/PEX-Tubing-516000
I just did radiant heat and a new boiler at my house. Since it is a low temp boiler, I went with PEX tubing, and colored the cold return blue, and hot water from the boiler with red.
Makes it much easier to troubleshoot water flow issues..
That makes alot more sense than designate sizes. :High 5:
So I bet you have a couple 3/4 inch pieces handy to take care of your doors. :waytogo:
StuB
Virginia
Stu
K-10
Red and Blue are common to what I've seen in homes. I do beleive the Red and the Blue just depict the size of the pex whether it be 1/2 or 3/4 and then there is white obviously, and I think black is 1 inch but not common in households. I'm not positive on the colors thing, but yes its colored too.
Maybe the red PEX is for the hot side and blue for cold ? Either way....fixing a part instead of just replacing it is way mores satisfying to me, so I love this PEX idea.
Yup, as posted above that makes much more sense, and would explain why they don't come in green, orange etc. I guess yellow could be the line to the terlet as Archie Bunker calls a toilet.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
You don't even have to unscrew the bolt if you do the pex slip over. It takes all of 15 minutes to do 2 doors. It will take you longer to go to Lowes or Home Depot to get the stick of plumbing. For me its not a matter of the work, its the matter of funds. Sure its only $10 a new strike or $20 per truck, but I have 4 trucks, so instead of spending $80 + shipping, I'll spend the $3 and do all the trucks in a matter of 30 minutes.
I didn't replace my strikes. That's not somthine I really care what it looks like. I was ordering some other stuff, and just tossed in $2 for the two bushings. Since my truck didn't come w/int trim, it only took me about 2 min. per door. To each his own though. Since the default color was gray, and my truck is also, that worked out for me too.
bobehud
St.Louis
Bob
91' with early 80's drivetrain
Suburban K3500
454 carbed
all 6 doors done,love the noise they make when i shut them had already used PB lube on all hinges now the barn doors sound a bank vault closing
Huge difference instantly isn't it?? Actually quite mind blowing for such a nusience that is such a cheap easy fix.
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
Yeah now i know how many rattles i had wife asked what was wrong with Chubs ,she said the damn thing got real quite...couldn't help but laugh.
You don't know how much it rattles until you do your fix...
You mean you pex'd the 4 front doors and lubed the barn doors, right? :think:
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
I did the pex thing to the front 4 doors and i took a piece of advice from another poster i have this black duct tape its called gorilla duct tape stuff is unreal so the metal latch that bolt to the bottom of the body for the barn doors develop wear spots on the round part,three wraps of this serious duct tape and wow even with that the doors go thunk solid as a rock....lol.....:patriot:
So you've not even been a here a month and thru all the fun and games, its paid off hasn't it??? Such a minor cheap fix but its like driving a completely different vehicle now huh??? Hang out a bit, we just might learn you some other tricks too. It comes at a cost though. Now you have to take all of us for a ride in Chubs !!! :laughing1:
No ****? You put that tape on all 3 latches in the back? Mine rattle like a bastard.... :hmm:
I'll see how they do after I fix that rear cross pan thing.
Tdabney
