Door Striker Adjsutment
Gettin Faster
Virginia
Wavel
I will check that out when I get off work. I didn know you could access the panel that way.
I know this is an old thread. But I found it using the search box and it the people on this thread sound like they may be able to help.
I have a 84 K10 Silverado, while removing the door striker to replace it with a new one with the bushing on it. Whatever the Striker screws in to inside the door jam fell inside ove the jam. (I cannot reach it w/o cutting the jam open. Now the door will not stay closed as it no longer has any thing to grab. I just need some directoin on what to do at this point. My door is held closed with a strap and sits in the drive way. SUcks I just bought it a week ago.
Any and all help is GREATLY!!!! apreciated.
You will have to cut open an access hole inside the cab if you can not reach it from the bottom speaker area hole, and put a nut on it. Unless you can find where the plate nut dropped into.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Dont know if anyone still needing this but to adjust the door striker I just leave it tight and smack it with a hammer which ever way it needs to move. Now you dont kill it just a little goes along way kinda like fine tuning it...
Gettin Faster
Virginia
Wavel
I found the piece behind the speaker. Thank you to everyone who helped. This forum is awesome!!!!
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
How does this go?
You have to put some WD-40 or something on it before you start, and use an old deepwell socket and hammer to smack it on. It also helps to put the striker on a piece of wood to keep from damaging the threads. But you can put the pex on without having to split it.
MadOgre
NA
NA
NA
NA
NA
cool
rangerman
Oklahoma
Joe
Have you guys checked your door hinge pins and springs?
Its almost impossible to adjust the strikers with a slightly sagging door.
Georgeb
Wisconsin
George
K10 Burb Z71
You may be able to reach it with a strong magnet on a stick.....
DawgmanDew
