Door Spring Replacement
Turbo4whl
Downingtown, PA
Wayne
Does anyone have a special tool or trick to replace the spring that hold the door open without taking the door off or removing the hinge? googled it but only one video on it and he removed the hinge.
Thanks
Hector
The other day when you asked this question, I looked and did not find my spring tool. Today I had more time and even though the 10mm socket was not with it, I found it.
Door and hinge still mounted, takes about 10 seconds. Hook the bottom, twist and push down. You can do it with a pair of pliers and push with a hammer handle, only it is a bit harder to do.
LoStep
Niagara Falls
Hector
350 ci
Done Very easy thanks everyone for your input koodo's to Backfoot100
LoStep
Niagara Falls
Hector
350 ci
Turbo4whl, i can see how that would work , I'm going to make one, where does the 10mm socket come in?
Turbo4whl
Downingtown, PA
Wayne
Standing joke on this forum, the most lost tool, a 10mm socket.
Salty Crusty
Gary
c1500
^ I think that's pretty much internet-wide.
Saw a tattoo a few days ago of a 10mm socket with wings, "Gone...but not forgotten".
Elhuichol
