Dome lights problem
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Ive been trying to figure out why my dome lights have pooped out on me.
Dont have any power at the bulbs and my fuse was good that is if it runs off the ctsy fuse.
I've got a single white wire going to both of my jam switches. The pass switch has 2 male spade ends but only one wire. Did I loose one somewhere if not I think my problem may be in my dimmer switch
Halp
85k10383
Glengary, WV
Ross
K10 Scottsdale
It sounds like you lost that second wire to me. I would suspect the jamb switches more than anything. Mine are frozen solid!
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Nah
After poking around and staring at wiring diagrams
It looks like the power wire for them was unhooked on my fuse block
Dunno if thats it yet since I don't have a battery in lol
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Mine has a "Dome Lt" fuse I think. X2 for the jamb switch, I need to replace the one on my passenger side. That would be wierd someone cutting the wire at the fuse box for the dome light. I would also check under for carpet or thresholds. The wire runs under there and can easily get broken.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Nope not the jam switches
Ended up being the power wasn't plugged into the fuse box
Although right now I have it plugged into the wrong spot and they come on with the ignition :jester:
85k10383
Glengary, WV
Ross
K10 Scottsdale
I need a good diagram of the fuse block in my 85, where would be a good place to find such an animal? I am consistently draining my battery down to nearly nothing and I suspect i have something connected to the wrong slot somewhere. Sorry for the threadjack BTW
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
85k10383
Glengary, WV
Ross
K10 Scottsdale
Thank you! I also need a big bag of money to fall in my lap right about............
Now!!! Damn it didn't work that time! LOL
I actually really need a Fuse block map like would be found on the back of the panel door in a more modern truck. You know the sticker, on the back of the panel door, that shows what all the fuses control, and where they are in the panel.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
I need one of those bags too
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
count me in on the bags of money.
jlyon1006
