idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
NOT that crank!!!
If your going to weld on the oil pump it's a good idea to remove the bypass spring first. Heat can ruin the spring.
Can I put the bypass spring back in after I weld it?
How do you know it's pennzoil? Because you're both right. I use pennzoil platinum full synthetic in all my engines, except this one. But I was planning on filling it back up with Pennzoil as it's always been changed with pennzoil. Should I not use pennzoil anymore?
What should I use instead and why?
Also, I was looking on rockauto and saw a melling high volume/high pressure oil pump for $33. Is there a benefit to installing one of these? Are there any drawbacks? Would the high pressure cause problems in my older engine?
It was running when you took it apart? Then it will run when you put it back together.
Don't overthink it and turn an intake job into a parts truck.
Have not read all the posts. Crossover suggestion seems right on. My guess is the flappy valve on the passenger exhaust might be stuck closed forcing hot exhaust in the crossover all of the time. The extreme heat just causes the oil to overheat.
Check out this thread. I am now using exclusively Mobil 1 full synthetic in my truck as well as my bikes.
https://www.gmsquarebody.com/threads/lets-talk-oil.24512/
Pages of good discussion there
Eric, 30 year GM Tech here. That carbon buildup was caused by the intake gasket burning thru and burning splash oil. The rest of your lifter valley looks very good. Vacuum it all out, re-install the intake and RUN IT! It will be fine.
Hear hear, you already cleaned it up put back together and run it.Eric, 30 year GM Tech here. That carbon buildup was caused by the intake gasket burning thru and burning splash oil. The rest of your lifter valley looks very good. Vacuum it all out, re-install the intake and RUN IT! It will be fine.
Wow, that thread was all over the place. But, the general consensus seemed to be mobile 1 full synthetic 15w-50. Does that sound right to you?
