Do I restore my AC or?
saltdog
US
K20 Suburban
It it were me, unless restoring to factory specs, I'd replace everything with a modern set up and pull a vacuum and be done with it. R134a just does not cool nearly as well as the original R12 Freon. R134a will not only leak from the 0-rings if not replaced, but can even leak through intact hose OE walls because R134a molecular structure is smaller than Freon.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
That would be an expensive and time consuming proposition. I might consider this if I were building a daily driver but I am building an occasional use truck. My 1987 GMC is at the body shop and that A/C hasn't worked in a long time. The truck was not really used much for the last 20 years. Now that I am restoring it, I plan to get the A/C working again.
My plan is to replace the compressor. My original one is really no good, noisy. I will replace the condenser, evaporator and accumulator since I have them off the truck now. I will replace the hoses with barrier hoses, again since I have them off the truck. Then I will charge with R134a.
My personal experience is R134a does a good job replacing R12. I live in Connecticut and we do get some really hot and humid summers but nothing like FL, TX or AZ experiences, especially with the sun load in those states. The systems in these trucks is way oversized. A Suburban has the same displacement as a regular cab pickup despite the volume of the cabin and amount of glass.
I would also suggest adding some insulation. It will cut down on the heat load and make the cabin quieter.
Battlac40
New Mexico
James
K1500 Sierra Classic
gm says r12 to r134a you do 90% of the r12 fill, then subtract .25lb from the result
You would want to of course have all the r134a components possible like condensor and a new drier, and change orifice tube.
GM would have preferred a high pressure cut out switch installed, they did sell them
15981985
but thats for use with a R4 compressor, id frankly disregard that specific use with the previous compressor type. A pusher fan that keeps airflow while idling would probably prevent the issue that they are designed to prevent
Is there a differance or what is the differance on process for an 81? -Thanks
great snip! @AuroraGirl
gm only initially retrofitted the instructions to 1988
After some years they made 1984 for some cars but they never officially went back further than 1988
but the AC in the trucks, to my knowledge, should be unchanged to the year they started using the R4. if you have an R4, i am pretty sure it would work for you.
but the previous compressor years, youd want to be mind ful of the system charge if it was different and any possible changes electrically. im not certain when r4 came around so thats about all I can say to that, otherwise it seems many guys do good just putting a crossflow in and changing seals/hoses and charging up with a compatible oil and a new dryer.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
My 1981 Pontiac Grand Prix had an R4 compressor. GM was using them at that time, at least in the A bodies.
I thought G bodies were 1982-1987 and A bodies were 1978-1981? Not that it matters. I may be wrong. I was a Ford/Volvo tech in the mid80s.
1979 g bodies are the same generation through the end of the rwd g bodies , but they have a revision in the 80s
A body is a confusing mess they had A's prior to 64 but general concensus is A's started with the 64 midsize GM(Chevelle, F85,Etc.) Through 77 then in 78 they down sized, depending on who you believe the remained A's until 82, then G's from 82-87. I call 78 up G's.
W3T1
