Disconnecting the transfer case from the 4speed, 1984 k20 Suburban
FLAKEBABY
St. Louis
Thomas
K20 Suburban
i am restoring an ‘84 Suburban pulled Manual transmission w/transfer case. To separate those two, is it as easy as simply unbolting them and pulling them apart? I’m not sure if there are any tricks. Any help is appreciated
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Yep, just unbolt the t-case and slide it off.
The88
Mhmm
South Louisiana
ThatGuy
Just be aware of the weight and awkward position you may be in if you are laying under the vehicle pulling it. They can be a little heavy when you are on your back with little room.
78silverado
