Desperately need rod from ignition switch to key.
73c20jim
Tombstone, AZ
switch without removing the switch??? Maybe just loosening it???
Gotta struggle with it tomorrow.
Iirc, you have to loosen it a lot.
73c20jim
Tombstone, AZ
Rod pops out of ignition switch when key turned to accessory.
Help, Please.
Something must be bent? The switch must sit flat and parallel to the column so the rod will stay seated.
73c20jim
Tombstone, AZ
I'm guessing the rod. Gotta check the parts truck. Steering column was pretty messed up though.
Just checked. no rod.
Gotta find a new one.
73c20jim
Tombstone, AZ
Seems like it's an assembly.
Switch rod and rack assembly
2.195
73 CK - 1,2,3 w/ac (exc tilt) ROD ASSEMBLY w/ ignition switch rack 7806117
73c20jim
Tombstone, AZ
Found one on Amazon. They got 3 left.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I agree this .
Bend that baby flat, save time and trouble.
Column has to be disassembled to replace.
73c20jim
Tombstone, AZ
73c20jim
Tombstone, AZ
Mine is bent to ****.
ExtraZ
