LateOnTheBrakes
5.3-Swapped 86 CUCV
- Feb 2, 2020
- Virginia
- Joshua
- CUCV
I am thinking of converting back to the drive by cable setup for my LS swap. I got the blue/red PCM and cable throttle body when I was at the junkyard, before I learned how to make the drive by wire setup work.
The problem I am having with the DBW setup is it stalls when I am decelerating and push in the clutch with my SM465. I have the Dakota Digital 8K pulse generator and my PCM was programmed to work with 8K on the VSS. It still dies routinely.
What cable are you guys using for the DBC setups? Can you use a Vortec cable with the stock K30 pedal? Any troubleshooting I can do to keep the DBW setup?
