dash removal.....
Chadwick
oakboro, nc
Chadwick
1/2 ton
How do you get the metal dash out of my 76? I have everything else out, but it appears I can't remove it with the windshield in. is this correct?
8T6K5
AZ
L98 350 TPI
Should be about 6 retainers behind it and 3-4 small bolts in front around the glovebox
EDIT: I didnt see "metal" dash....was thinking dash pad.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
The dash is spot welded to the windshield pinch seam. You would have to drill all the spot welds out to remove the metal dash.
Chadwick
oakboro, nc
Chadwick
1/2 ton
I appreciate it. I'm definitely not doing al that haha.
75-250-KY
Louisville, KY
250 in line 6
My 75 - just had like like 8TK said about 3-4 small 1/4" sheet metal screws and there are just tabs that hold it down - you just have to pull straight back. Did not have any spot welds- the tabs just slide in. You are referring to just the top pad - metal shell underneath correct?
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
NO 75 he is refering the actual dash that holds everything not the top pad
thom9719
