Dash differences
72velle
Kevin
I wasn't sure where to post this so I will post it here :)
I have an 84 C10. My buddy pulled a nice dash cluster from what he thinks was an 87. It is in better condition than mine and looks the same as mine except it has a clock. Will this fit my truck and what do I need to do to install it? Do I need a new harness because of the clock?
TIA,
Kevin
Dmack
Central OR
Dave
It will physically fit, but usually the wiring connector will need to be repinned to work with your harness. When I put an 84 harness into my 83 cluster, I found the wiring harness pin out diagrams , on this site iirc, and repinned it.
'84 and '87 should be pinned the same. However, the pinout for a standard (idiot lights) cluster is different than the pinout for a cluster with gauges.
A couple of the warning lights may be pinned different too, but that can vary. Service Engine Soon light and 4 Wheel Drive light, for example.
Number 6
Mexico
C.O.
Suburban
'87 Mexican w/manual. The the automatic position window (which you can not see) is painted over !!!
Besides the goofy Corsica-ish steering wheel, look at that dotted pattern rubber floor! Very interesting.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Has the window at the top center of the cluster too...
Wallace6
Wyoming
Ray
Suburban
Yeah and definitely a shifter boot difference. I'm pretty sure my cluster just has black electrical tape over that indicator.
blackmfcowboy
