I wanted to preserve my OEM dash bezel on my '74 build, so I bought another " '74 " off Ebay. I reworked the gauge holes to accept my Speedhut gauges and had it hydro-dipped in Red/Black Carbon Fiber. When I went to install it, I discovered that the light hole was huge (on my OEM the light knob come out of a small hole in a raised pyramid shape) and the hole for the wiper slider was wider and offset to the right - real close to the bend in the bezel.
Essentially, the Ebay dash bezel was unusable in my application and it's going to be sold.
I made the mistake of assuming the seller's description was accurate and that '73-'87 actually means everything in that year range will fit. IT DOESN'T. All it means is that the mounting screws will line up. . . sort of. I also made the mistake of not comparing the two bezels before doing the work, as it was 90 miles away at the time. My Ebay bezel is clearly a later '70s version.
It seems that there are a lot of one-off's in the '73-'74 years that makes the '73-'87 designation misleading on many, many parts when you own a '73-'74.
