Started in on it again today. Took the cover off and snapped a pic of the current mesh pattern...
You can see the pattern is like a very wide U shape, right at the top of the tooth. Time to tear it apart. I wont waste a bunch of space for every little thing I did like how to knock out a bearing race, but I will show where the shims go under the large pinion bearing race...
Which I added another 0.010" shim. I know, I said 3-5 thousandths but after reading the assembly manual it said to make a large adjustment (10-20) first then smaller adjustments after (3-5).
This is kind of an important pic, showing how the bearing race is recessed into its pocket, you have to make sure you're driving it all the way down against the shims...
Pinion installed, carrier installed, time to put the shims beside the carrier bearing race...
I cant remember how much shim is there, but it equals less than 0.002" endlash (left-to-right play).
Now, I was expecting a lot more adjustment to get the mesh pattern right, but it looks pretty damned good...
Now comes the fun part. The D60 sometimes does, and sometimes doesn't use a crush collar for pinion bearing preload. Mine does not. Instead, it uses shims under the outer pinion bearing to set preload...
This required removing and installing the pinion 3 more times to get right, but honestly I'm much happier with the results. No matter how much you tighten the pinion nut, the bearing will only have so much preload. Pain in the ass to get right but once it's there, you know it's right.
Next, I took everything apart again lol and put in the pinion seal, then the internal axleshaft seals, which you can use the handy dandy spindle nut spanner socket for the D60 to install the axleshaft seals, with a thin coat of black silicone along the outer edge...
Install the carrier again, this time with 0.005" more shim to give the carrier bearings some preload, sounds easier than it really is. Backlash is in spec at 0.006"...
Next is all about cleaning up the cover gasket surfaces, spread on some black silicone, set the gasket on, give it a couple minutes to cure a little, then assemble!
Next step will be cleanup/paint for this thing, then the hub assemblies.
