DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Last weekend I noticed the dampener isn't rotating true anymore. I want to replace it with a new one before it comes apart. I was going to place the order on Summit just now, thinking it would be an easy purchase. I then see there are various options. 8", 6.75", with degree marks, without degree marks. Was hoping to see AC Delco as an option, but no. Dorman, the mark is clearly not lined up with the keyway. The summit brand ones, they appear to have the zero lined up with the keyway, and have degree marks. I don't care one way or the other about degree marks, but to keep it simple, the one mark is sufficient.
I can measure the diameter so I get the same size. But what is deal with the mark? Are they supposed to be lined up with the keyway? Is the keyway TDC at zero on the tab? Any info is much appreciated. Thanks.
