Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
one of the last parts I've yet to purchase for my truck's engine are the headers. I just can't make up my mind. I've run long tubes before with the 327. my issue was clearance to the front drive shaft. it was under 1/2" from collector to driveline. I also wasn't excited about them hanging below the bottom of the frame. I pulled them and got some shorties. I've read that some guys don't have this issue, but I'm assuming that different trans/t-case combos will change clearance.
I was all but decided on some stainless steel mid lengths until I watched an episode of Engine Masters last night. the hp and tq spread down low was significant between the mids and longs. now I'm questioning things again. since more tq and hp down low translates to driveability and likely mpg blah blah blah... the difference was their test engine had more hp than my vortec 350 will have, and therefore greater airflow requirements. maybe I would see as significant of a difference in a 350hp/400tq truck motor. on to the questions and setup:
I have an l31-r stock everywhere inside. it has a sniper efi kit. I'm not sure if the wide band o2 sensor being further or closer to the exhaust port would make any significant difference, but they have instructions on how close to the collector the wbo2 sensor should be. so obviously the bung would be further from the exhaust port on the long tubes. trans is a t-400hd and t-case is a 208. I'd like to hear from guys with the same trans/t-case, but maybe I'm overthinking that part as far as fitment.
does anyone run or know of a long tube that clears the front drive shaft by at least an inch? maybe using a header with a weld on type collector, braided isolator flex section, then out to my exhaust pipes would give the clearance needed? not sure if all long tubes would be like this, but mine were angled downhill very slightly at the collector, which was annoying but could be corrected by the isolator flexy piece.
pictures of your setup would be great
