notverrysmart
- Aug 8, 2012
- washington
- EJ
- suburban
Ok, as the title says, my dads 92 chevy astro 4.3l tbi will not start. It was having issues with cold start and he replaced the cap, rotor, and plug wires, and the plugs were replaced not too long ago. The cold start issue seemed to be cleared up and he had no problems for a couple days, then they returned with it running like crap once it started. He limped it home, and when he got home it wouldnt start and we traced it back to a bad fuel pump. Wouldnt turn on when jumped directly from the battery.
We replaced the fuel pump and you can hear it turn on, however it still will not start. when cranking instead of a cone spray from the injectors it is just dripping at about the same rate on each injector.
My thinking is there is not enough fuel pressure at the injectors since I doubt both would fail at the same time and at the same rate and the dripping (only while cranking) tells me the ecm is telling them to open.
Im 90% sure that the hoses from the tank are hooked up correctly since once again the injectors are getting fuel.
So Im leaning towards a pressure regulator or possibly a clogged line. Also the fuel filter was replaced somewhat recently.
So am I heading in the right direction? What would be the best/most simple way to test this? If Im missing any info please let me know and I will add it and if I think of anything I will add it.
