- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Before spending a dime on anything, measure the voltage at the battery stud on the alternator. If it’s more than a couple tenths power than at the alternator, fix the wiring.
Is your upgraded alternator one that is capable of remote voltage sensing? If it’s based on a CS130 case I’m pretty sure one of the 4 pins in the connectors is used to remote sensing of system voltage. If so, connect that terminal to the power cable near your amp.
Ahhh, so THAT'S what the extra pin is for! Does it get hooked up in addition to the normal wires in the harness?
