Crisp, clear pic of a square's fuseblock for those looking for same.....
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Obviously, there were changes that had to be made when glass fuses went extinct.
We have an 82, an 83, an 84 and a 86 here, mixture of 2wd and 4wd, half ton and 3/4 ton, and they all used the same fuseblock.
heres a better photo. mines in pretty good shape letter wise. hmm.. might have to snag a direct-on-photo
I thought irecall reading here that the locations changed on certain fuses or additions made. i could be mistaken
gmachinz
Harnessworx Inc
Iowa
Jabin
Nice! I’d actually like to find a complete, uncut 79-83 fuse panel assembly to add to my collection as well! That’s a very clean one you have!
For creating products or just to have one?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
That could stand a goodly amount of clarification.
What kind of products could one manufacture with a fuseblock and wiring harness ?
Well, he is our residential harness-man. he recreates harnesses with added functionality, OE design, or just for different stuff. And a fuse block gets hooked into by the junction under hood, yes?
Hes got you if you need something.
For example, I had a thread about tail light harness wiring, and he sells a whole new harness OR one with a 7 plug wire built in, just have to connect to a trailer brake controller and a tiny bit other stuff.
Good ****
gmachinz
Harnessworx Inc
Iowa
Jabin
I have plans to release new factory style fuse panel bulkhead because the aftermarket will never offer factory fit blocks for these trucks the way I can. For now, I’m in the market for purchasing both halves of 1973-up fuse panels as well as 1985-up convenience center connectors. They can be completely cut short with wiring but I need the printed areas nice and crisp. I need to find a few guys who routinely part these trucks out most likely lol
FireTruck1984
Michigan
Ted
1984 and 1984
Is this any better ??????
Good thing I gave my smartass side a vacation, otherwise I might suggest checking to see if your glasses needed cleaning .......
I see the fuse marked WIPER, is there a separate fuse for WASHER FLUID MOTOR ? My squirters stopped working
