crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
Note #2: ALL rear brake hardware SOLD, and cables! Thanks Randy aka yenner! Still have rear backing plates, park brake pedal, and 1st cable from cab to frame as far as rear brake system goes.OK time to try to get more truck fundage! I cant find the particular driveshaft I need at all, so I'm going to part the front and rear 1/2 ton axles out and probably have to buy the 3" tube to make my driveshaft longer (more expensive than cutting a LWB d-shaft down). Here's a list of parts to start with, and a ballpark value. I'll know more what they're worth once I get them out and clean them up. Everything will require buyer to pay shipping:
3.73 Motive Gear ring & pinion for 73-87 Chevy front Corporate 10-bolt axle: $40
3.73 Richmond Gear ring & pinion for 73-?? Chevy rear 12-bolt axle: $50
Factory Limited Slip posi for 73-?? Chevy rear 12-bolt axle: $30
Factory Open carrier, complete with sides & spider gears, for 73-87 Chevy Corporate 10-bolt front axle: $25
Front Axle Shafts-
Inner long side: $40
Inner short side: $30
1- brand new outer stub shaft: $40
Other outer stub shaft is in bad shape, not for sale except as a trail spare for cheap.
Any combo of above, or all, make offer!!
Now offering the above with stub shafts and u-joints all together for the same price I had for the inner shafts alone!!
Rear Axle Shafts-
Each $20
Both $40
Both have perfect wheel studs, will include c-clips if you need them.
Dana Spicer locking front hub: $15
Front right spindle, hub/rotor assembly, calipers, caliper bolts, steering knuckles, cover+bolts: $Make Offer!!
Rear drums (like new),brake hardware, backing plates, complete parking brake system from pedal in cab,cables, brackets; cover+bolts: $Make Offer!!
NOTE: front backing plates SOLD!! Thanks Mike aka 1973 Chevy!
