Cost to swap in a 700r4 or a 480le?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Can you please explain? What is simple, spending minimum $500 ..? I understand a diesel engine controller can me modded to work... but that kinda
stuff is over my little head.
The TCI EZ TCU is 600, for ease of use I'd just go that route, 5-700 for a donor,that doesn't need to be built, then 600 for controller, puts you at around say, 1500 fluids and expendable stuff included.
You can do the Diesel controller, or a 411 PCM as a controller for less money and more effort.
Joe T
Houston
Joe
I thought the 700r4 had the same dimensions as the th400. Not the th350.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
The TCI is actually under $350 now. Really hard to beat that if it’s reliable.
Edit: technically you’re correct. For the whole shebang harness and all it’s $595
Joe T
Houston
Joe
My uncle had a 75 C10 he bought new and drove to work for 41 years daily. Only thing he changed on it was swapping in a 700r4 when the original died.
He said he bought a cheapo rebuild at Autozone and I want to say it was like $600 or $700; something stupid cheap. Heck this might have been 20 years ago.
Knowing him it was probably a quick clean deal as a machinist I dont think he would want it cobbled up.
Random access memory.
4WDKC
Southern Florida
Kacy
:word:
A 700 can be built to hold more power than stock but are never built proof. I have a bowtie overdrives stage 3 in my vette behind a 406 and not a single problem from it other than annihilating the rear tires thanks to the ridiculous first gear ratio but in a big heavy truck with big tires it becomes completely different. This transmission is now $2k then you still need to hunt down the 700 crossmember, drive shafts and linkage for tcase. The turbo ls guys are adding a shift kit and convertor to a trans from the junkyard and the trans is holding 700+ rwhp. To me this is a no brainer and I was planning this for my truck with the big block swap till I sold the truck.
Jrgunn5150
Ionia Mi
J.R.
6.slow
:word:
Yeah, the whole "700's are great transmissions when built right" argument kind of falls apart if money is a consideration in your world.
Unless you have one now, then it's probably more effective to build it and keep all your factory stuff. But if coming from something that's going to require driveshafts anyway? 80e.
stvaughn
