Converting 89 r1500 into a 1 ton 2wd
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
So, to kinda revive this, I met a guy today, spoke with him a bit, he's got a lead for me on a k30 longbed frame with axles.... He's gonna get back with me in a few days, thinking this might be opportunity to convert my 89 to a 1 ton, and while there may be a towing limit for my 1500 burb, a 1 ton suburban truly would be kinda unique.
A frame swap, possibly relocating body mounts for the burb wouldn't be an issue at all for me. Whatever it takes, I can do it.
Id love to make my beloved 89 into a 1 ton burb... It was dad's dream to make it a 3/4 Ton 4x4, but a 1 ton would be even better.... Figure while I'm at it, I'll powder coat the frame and all, and have a fresh clean frame.....
Updates will come (if I remember to post here)
Edit: here in NC, a weighted tag allows a 1/2 truck to tow more, just as simple as that.
They don't break your balls because you're pulling x amount with a 1/2 ton
Sent from my SM-G965U using Tapatalk
SDJunkMan
Black Hills of South Dakota
Jeff
I thought there was quite a difference between a pick up and burb frame. I thought the pickup frame came up sooner under the back seats.
Vbb199
Salisbury NC
Vince
Do you think so?
Can someone confirm? Pics?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Here's pictures of my K30.
Vbb199
Salisbury NC
Vince
This article I found shows wheel bases are similar on a lwb k30
But as bucket said, the rear of the frames are different.
So this maybe would be out of the spectrum of what I want to do, only because I don't want a hacked up truck, I wanted to keep this as clean as I could.
SDJunkMan
Jeff
I'm not sure, but when I was rebuilding my crew cab dually my cab was rotted out, so I was thinking about using the front of a burb and stretching the cab a little so I could use the fold flat burb rear seat. Seems like the pickup frame kicked up sooner than a burb frame. It's been quite a while, I could be wrong.
K5_489
Arizona, USA
489 BBC
What if I added addition support to the frame
(tubular crossmembers, x bracing, boxing)?
I have the means to make a 1/2 ton frame stronger than a 1 ton frame
Probably easier to just swap frames, maybe while I'm at it just add an additional frame support in the middle or where I see fit.
Merely adding a bunch of bracing/boxing/support/crossmembers/whatever does add additional strength to the frame in the sense of , and "beefing it up" will very likely cause it to fail sooner than just leaving the 1/2 ton frame alone if you plan on loading this truck up like a 1 ton, either with towing or with cargo payload (though it's unlikely you'll shove enough cargo in to the back of a Suburban anyways to really even stress the 1/2 ton frame).
This is very common misconception among MANY people - that bigger/beefier/more support equals stronger which in turn equals better. This also follows for most people that assume that a C-section frame is weak, with a fully boxed frame being bulletproof strong. Or like the often repeated "I drive a big truck because it's SAFER in an accident...those little tin cans crumple like tin foil in an accident, and my big truck barely has a scratch on it!!" (or using the same argument to claim that the big ol' land yachts of the 40s-60s are safer due to being made of REAL! steel that's thicker). Take a look at accident stats some day...modern vehicles that crumple like tin foil are FAR FAR FAR FAR safer in accidents, even when you look at pre-air bag vehicles of the 90s. You're also safer in a modern tin can car than you are in a new Silverado. But I digress here, lol...
Anyways, if you have the chance, take a look at the frame under any OTR semi truck - just about every modern tractor uses a C-section frame, and you can see those frames twist up like a wet noodle when they're pulling away from a stop while heavily loaded. This flex very beneficial when under a heavy load. The boxed frames typically ARE "stronger", but they also tend to have a much narrower window of overload and failure. Meaning that if you push a C-section frame too far occasionally, it will flex more, and may permanently deform if you go too far with it, but generally won't outright fail. The "stronger" boxed frame (or one with too much additional bracing in it) is much more likely to crack/break/catastrophically fail when pushed too far. There has been a considerable amount of suspension redesigns on these modern frames to absorb more of the stress in the suspension, rather than allowing the frame flex to absorb it. Many of these are also of the hydroformed variety, which much computer analysis goes in to, rather than simply boxing in existing design C section frame rails.
Then comes what your additional bracing may do - more than likely you'll add additional stress points, where frame failure is more likely to occur under loads as it will tend to concentrate stresses at those points, rather than spreading the load across the frame. Think of how a weight distributing hitch works - spreads the load of the trailer across the entire frame to both the front and rear axles of the tow vehicle, thereby increasing the amount of towed load that the vehicle can safely handle, rather than just adding additional capacity to the rear axle via heavier springs/air bags/air shocks/etc, and increasing the lever force of the hitch pushing down against the rear suspension points.
What you really need to do is compare your 1/2 ton frame to a 1 ton frame, and mimic those differences. The biggest thing you're likely to notice is that the 1 ton frames are considerably thicker in material compared to a 1/2 & 3/4 ton frame. Something like 50% thicker. I don't recall the specific numbers right off the top of my head, but the 1/2 & 3/4 ton frames are somewhere around 1/8" thick, with the 1 tons being 3/16" thick. Doesn't seem like much, but it does make a considerable difference in strength from a load capacity standpoint. Thus, what you would be looking at doing is to plating the entire frame with additional material.
However, at least in squarebody land, there is an upside for you here. The diesel & 454 4WD Suburban frames are also the thicker 1 ton dimension, but formed to fit 'Burb bodies rather than pickup beds. This would get you the frame beef you're looking for, in an almost bolt in package. I don't recall off the top of my head if the diesel/454 4WD rear axles are on 1 ton pickup spring spacing or not. I want to say not, but don't quote me on that one, lol. The reality is that you're very unlikely to ever load up that frame to the point of failure by the amount of cargo that can fit inside a Suburban body, or the amount of weight that can be put on a bumper pull trailer...assuming you don't get dumb with it....like hitching up to a fully loaded 45K double tandem equipment trailer, lol.
FWIW, I too did some serious research in to this several years ago, as I had a super nice '06 Hemi Ram 1500 2WD, but really wanted a 3500 4WD, and had more time than money in those days. Even with what I expected to get out of my 1500 by selling it, the delta in price to a similar condition 3500 was just too much, and I figured I could just modify what I had for less money. In the end though, I ended up selling the truck, and compromised on an older F350 diesel 4x4 for the heavier hauling duties, and eventually got the K2500 diesel for the daily driver/lighter duties.
SirRobyn0
There is also a legal issue to think about. Obviously it's totally fine to do whatever upgrades you want whether it be making changes to the current frame or swapping or whatever you decide is best, but from a legal stand point the GVRW, hauling and towing ratings will never change, it'll still be what's printed on the door and tied to the vin. I know in a lot of states it's extremely unlikely to ever be weighed / ticketed, but if for example you were involved in an accident and your over the GVRW you could at that point be ticketed or worse. Look I'm not encouraging nor discouraging what your trying to do, just giving you more information to keep in mind.
Vbb199
Salisbury NC
Vince
SirRobyn0
In Washington state pickups / SUV's do not have to stop at weigh stations. But if involved in an accident, and obviously over weight they will ticket and if there is a fatality they can arrest even if the over weight vehicle is not the one at fault. Some states, if you ever travel, do require pickups and SUVs towing to stop at weigh stations. I'm just trying to make a point about VIN tags, and legal loads, which varies by state. I'm not trying to bust your balls, or otherwise tell you what to do. :) I've done my own share of suspension improvements for the purposes of hauling / towing more so I do get it. I just wanted you to know there is a certain liability. If you we not already aware.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Maybe all you really need is a D60 and 14 bolt...?
And cross over steering..
and a big block..
78silverado
