Gman73
- Aug 19, 2021
- Sacramento
- Gary
- Ck20
- 350 v8
I'm confused, replaced my front wheel bearings on my 73 k 20 did the back bearing to spec ends up at about 35 ft-lbs with the backing off, however the consensus on this forum is the fronts should be torqued to about 120 ft-lbs, I have the factor serv manual and the factory overhaul manual and the service manual call for the fronts to be 50 ft-lbs I'm reading it but is this correct? If so I need to do some loosinin lol
