87ChevyR10
- Sep 2, 2013
- Kansas
- John
- NA
- NA
- NA
Howdy,
I've been away for a while and I finally got the chance to replace the headlight switch. After doing so, I discovered my top beams are both hi/low and the lower lamps never turn on. I got to looking at the plug for the top lamps and they are 3-prong plugs while the bottom lamps are 2 prong plugs. Everything looks factory.
Now here's where my confusion kicks in. Why would Chevy use 3 prong plugs for the top lamps? If the bottom lamps are meant to be the hi-beams, why give the option for the top lamps to use both? Unless I am misunderstanding what I am seeing. The low beams have never worked since getting the truck. And up until this last weekend, anytime I tried using the hi-beams, my headlights would go dead.
So, yeah, I'm really confused over my headlight setup. I've been wanting to get the the single lamp bezels from LMC; and since I now know only the top pair of lamps work, I see no reason not to convert at this point. Plus, the new bezels would allow me to move the front signals.
Anyways, can anyone figure why my head-lamps are setup the way they are?
