Condenser Replaced - a few pics
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Anyone have a link to a trustworthy A/C condensor nowadays for a late 80s square? I had got one that was "perfect fit" for my rig, but clearly wasn't. even with moving the mounts the lines hit into the rad support regardless; they're supposed to stick out and do not. Not sure the exact number but it is a Spectre condenser, and so far it's ****. Any help would be appreciated!
rsbad454
California
RS
C20 Silverado
6.0L LQ4
Did you figure anything out? I ordered one of these too and it's way smaller to fit normally in core support.
yevgenievich
Place
Name
Year
Model
Size
UAC one looks similar. Other UAC condensers that I have tried holding so far. 636420 unit mentioned a while back has been discontinued.
dd1990
Ventura CA
Suburban 1500
You have move all the condenser bushings inward, there extra slots to slot in, top driver side had to drill a hole abolt the original bushing, I also cut some of the rubber bushing in the middle
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
no i never figured anything out. in fact, i'd decided to remove every last component of the AC system in that truck and swapped it to a heater only setup. Kinda how i like my Squares nowadays
83 Box
Louisianna
c10 Silverado
If you are converting to 134a you should always change the dryer. The dryer cannister contains a dessicant bag that grabs any moisture from the refrigderant. Also, while the R12 orifice tube may work (sometimes, system dependent) a dedicated 134a tube will give a lowewr output temp. It has been my experience that R12 systems typically give 35 to 45 degrees of temperature separation while 134a is usually about 25 to 30 degrees. This is of course location and system dependent.
pchango
