Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
I'm not going to look through 156 pages of posts to see if anyone has a post on a radiator problem. If anyone knows of one just move this one to there!
I installed a 3 core all aluminum radiator recently and now my water temp. gauge won't show but a dab over 180 F. It's hot down here in Louisiana and driving around on the streets I know are hot as hell and the water temp. is only 180 degrees? I've heard that these custom radiators will run 20-30 degrees cooler, but...really? It really is running that much cooler than my 3-core factory brass/copper radiator that used to run 190 degrees in summer and a little hotter on really hot days? Well, that's not good because if that's the case it's not letting the engine heat up to operating temp. And it's not letting the oil heat up to operating temp. either. You know when the oil is cold it robs horsepower due to the thickness of the oil. And besides the oil is supposed to operate thinner, not thick.
If this is the case, that it's running that cool, it will be a real problem this winter. I'll have to break out the cardboard to block off the radiator to get it warmed up to operating temp. I mean I like my engine running cool, don't get me wrong, but I would like to see it between 180 and 190.
