Clutch Types, Z bar manual and Hydraulic
Heavychevy79
North carolina
Elliott
After looking through a couple different forums, I found that the 2 support rods coming from the pedal, they go through the master cylinder is that correct?
Georgeb
Wisconsin
George
K10 Burb Z71
I am almost certain the pedal assemblies are in fact different between z bar linkage and the hydro clutches.
It does sound as if you might have the hole for the clutch master misaligned. I was hoping someone could make us a template or give us measurements to make our own so we can drill the hole in the correct spot.
I will be making just such a template. I will try to post it as PDF when I have it so others can use it as well.... Will be a month or so before its done tho.
mcflurry
