Powerhouse Ranch
3G Connoisseur
- Jan 6, 2021
- PA
- Luke
- '80, '86, '88
- C25, K5, V15
Your asking questions for a possible fix, and others have responded with valid questions. There could be several answers to your problem. But @AuroraGirl we can help you if you investigate and make sure things are connected right and the best way to answer you is if you provide visual.
Are the bushings in the Clutch/brake assembly new or original. Can you move the pedals side to side? Is the clutch linkage rod new, worn? Does the Z bar have all of it's components? Is it worn at the linkage rod connection? Are all the springs attached correctly and new or old? Can you manipulate the linkage rod with out moving stuff? I provided a couple pic's and don't mimick my spring locatons on the Zbar they are probably not right, just hooked up!
EXCELLENT!
