Clocking steering wheel
K201979
Winona, missouri
Hippie
350ci
Sure the box hasnt got something pinched between it and the frame? Dunno if it would be enough to cause that much difference tho. Rag joint is keyed(sorta), pitman arm is keyed(sorta)not sure what might cause that.
K201979
Winona, missouri
Hippie
350ci
Box not centerd before reinstall?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Everything the same. I haven’t done the drag link or tie rod yet. Just hooked it back up the same as it came apart.
When I pulled the steering box I left the pitman arm attached. When I hooked the pitman arm back to the drag link after mounting the steering box, I didn’t need to turn the steering box because the pitman and drag link lined back up...
Besides the drag link, reclocking this splined connection seems to be the only way to change anything...
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Box is definitely tight to the frame
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I guess I can just drive it first. At least then I can see what direction the wheel is pointed when I’m actually driving straight down the road.
That way I can know exactly how many degrees out I actually am. So far, I’ve just pointed the wheels straight ahead in my gravel without moving forward or backward...
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I’ll exhaust all of the suggestions and get it right.
I’d feel kinda like a shmuck rolling into my buddies alignment shop with the steering wheel that out of whack. I’m bringing my new drag link and tie rod in for him to throw on when he aligns it.
This is where I’m thrown off. Drag link was never adjusted and it was clocked straight before tear down. Wouldn’t adjusting the steering wheel clock through the drag link pull my pitman arm out of that ideal perpendicular position when the wheels are straight forward?
BINGO, there's your problem. I can tell by that new boot and new arm. Adjust it there and you'll be good to go.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Lol. It’s the original drag link, boot, everything. Only the cotter pin is new.
I guess it’s in pretty good shape for it’s age!
K201979
Winona, missouri
Hippie
350ci
That pinch bolt/splined connection at the rag jont has a big flat spot that has to line up, so it is "sorta" keyed. Maybe when you drive it, it will be good. Might just look like you have the wheels perfectly straight. Usually takes me trial and error to get just right(shadetree mechanic). :crazy:
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
That pinch bolt/splined connection at the rag jont has a big flat spot that has to lined up, so it is "sorta" keyed. Maybe when you drive it, it will be good. Might just look like you have the wheels perfectly straight. Usually takes me trial and error to get just right(shadetree mechanic). :crazy:
More of a mechanic than I am, though I’m not a very high bar, lol
If that’s keyed too, I guess the only way to make it right if nothing is damaged/bad would be the drag link, as you said.
I guess I’ll get it on the road and see what’s what.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Did the suspension height change? New springs, or something like that? It doesn't take much.
You can tell me that all you want and I still won't believe it. Sorry. If that's a current real time pic, Nope, Not buying that for an inth of a second. That is NOT original OEM to that truck. JS
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Original may not be the right word. It’s the same drag link that’s been on the truck the 10 years I’ve owned it and it definitely did not look new when I bought it.
But then again.... So wtf? Do you even drive that truck? Looking at the pic again, all the components look brand new. Tires, axle, springs, Pitman Arm, even the nuts look brand new. What's the story on that truck? I mean, I'd still find it hard to believe that's the original OEM drag link but still the rest of it looks pretty damn clean too.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Same springs. I did pull all the leaves and sanded/repainted everything. The HD front shackles from ORD apparently lift the front 1/4”. Is that enough?
luis1jr
