Cigarette lighter not charging ?
Woodman77
Idaho
Woody
Suburban chevy
Use this for charging phone and other electronics. wondering if there is a better way to charge?
have checked fuse. any ideas are appreciated. Thanks Woody 1988 Sub
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I've noticed some cig charger accessories don't work very well with the older style plug in these trucks. There's not much different they just don't like these plugs, try another cig plug accessory.
How have you verified it's not working? Just plugging something in?
Woodman77
Idaho
Woody
Suburban chevy
Yes, plug and no lite comes on. So, do you think the whole lighter system needs replacing or just the adapter that goes the the unit?
Thanks, Woody
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Thanks, Woody
Get a test light and ground it out somewhere good then touch the center pole in the bottom of the cig plug to see if it's getting power. Be sure not to touch the sides of the socket while touching the center pole, it will ground out and arc.
If it's getting power, then you'll either have to swap out your plug in accessory, or change the cig lighter.
Rusty Nail
Rusty
350sbc
I bet the spring loaded charger tip isnt making contact. Try a different charger. If it will glow a cigarette lighter that's not the problem. My bet is on your new plastic, not the old metal. There isn't anything there to fail aside from what you have introduced.
Woodman77
Idaho
Woody
Suburban chevy
i AM ON IT !
Thanks You Guys.
Woody
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
You were RIGHT !
I replaced the Charger .... And IT WORKS !
Thanks So Much....
Woody
Some this new plastic stuff works, some kind of works, some don't at all. Glad it was cheap and easy!
chevelless07
