Caulking In Bed
backyardgarage
Ocala
K-5
I’m sure it works great. I feel it’s basically the same stuff as auto seam sealer, having used both, as both are urethane sealant. Never looked to see if 5200 is paintable though as I’ve only used it in marine applications.
It's pretty much the same. I was introduced to it back in the last 80's when I worked at a firetruck manufacturing plant. We used it on all of our seams, then we primed and painted over it. I believe about 10 years are so, they switched it up to a product from Stika call Sika-Flex. It dried a little faster, so you had to do smaller sections at a time to smooth it out. But I still use the 5200 on my stuff
I used 3M 08308 in black, got it and the gun off Amazon. Worked great and was super easy to work with. Took longer to scuff the areas it was going down on then to put the sealer down.
I agree with the 3M seam sealer recommendation, my Dad recommends 3M Fast 'N Firm (08505) but I haven't used that one yet. I have used a few tubes of 3M Urethane (08362) and have been very pleased with it.
I've literally used hundreds of tubes of Fast 'n Firm. Never a single issue with it, although the name is a little misleading. It only skins over fast, it takes a good long while before it actually firms up.
Auburn, Washington
We used NP1. Got it in a bunch of colors at Lowe’s about $7 a tube. Used it on cab floor repair sealing top and bottom and bed seams before rhino lining. It’s been over a year and we are water tight everywhere and no cracking even in Texas heat.
Randy and Easton
Good stuff, except wrong application IMO. It should bond well and not crack, but it, like other NP1s and all the different Sika Flex products I’ve used are far more flexible than seam sealer (and consequently less durable in an application like inside the bed or the rear bumper seam, or even cab seams as just a push with your fingernail can/will deform it which will pop the paint off if it’s a painted surface). The stuff you used is specifically designed to be flexible like for expansion joints in concrete. It’s make to stretch ___% of its width and retain the bond to the substrate.
Just use seam sealer or something like 3M 5200 that gets much harder to the touch.
I’ve used AC Delco and 3M (or SEM) recently. Both are still good a couple years later now.
custodian
Catawba
William
5.3 LS, 350
This is what I'm looking at using. ACDelco GM Original Equipment 10-2013 Body Joint and Seam Filler Compound​
dannyphx
