- The orange wire should be hot all the time, if the courtesy lights fuse is good.
- The white wire is grounded when one of the doors is opened (although these door switches can get corroded), or when the headlight switch is turned counterclockwise past the detent (you should feel a sight click)
- If the cargo light switch is up/on, then when the courtesy lights come on (for example, you turn the headlight switch fully counterclockwise), the cargo light should also come on.
Troubleshooting
On the driver's side, in the rear cab corner, there is a connector for the cargo light wiring, and it should just pull apart. I would first check there to see that you get power and ground on the orange and white wires.
Assuming you had power in the cab corner, then follow the wires and move up to the cargo light switch (two screws hold it in). These switches are not very well made, and it may not be making a good connection (mine has issues). They sell a product called DeOxit that you can spray on the contacts of the switch to remove oxidation, which may help it work better.
Assuming you were successful in getting the switch to work, now check for power and ground at the cargo light. If you don't have it, then its the wiring between the switch and the light.
It would be best to buy a cheap multimeter at WalMart or Harbor Freight. I've seen them for as little as $4-$6. To verify ground you need something that measures when the resistance is zero, not just whether there is 12 volts.
