Carburetor Problem
crazyman1018
Angier NC
Conner
Hi, i have a 1983 K10 square body with a 305 in it and i believe that the carburetor i have is the wrong carburetor as it is not cooperating with the truck
i got this truck in may of last year in bad condition the previous owner didn't take care of it and blew up the transfer case we got that fixed now i decided to rebuild the carburetor i got it mostly together but wouldn't you believe the guy also customly rigged up the choke system and i have no idea how it goes back together or even if its the right carburetor for the truck can anyone tell me how to put it back together or where i can take it to get redone
thanks
:lazer:
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
What carburetor is it? If it's a Quadrajet, it's the right carburetor. If it's not, it needs to be the right CFM. 500 is plenty for a 305 and no more than 600. If it's not a Q-Jet, you need to find what model it is and see what CFM it is. Are you sure it's the carb? Like have you checked to see if you're getting two squirts of fuel when you actuate the throttle?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Of course, but it's a Quadrajet. The same carb, in theory, can run a 265 SBC in a Tri-Five Chevy or a 454 in a 35' Holiday Rambler.
Georgeb
Wisconsin
George
K10 Burb Z71
Try to post some good up close picks of the choke linkage setup. Also tell us the part number on the carb. Should be an 8 digit number starting with 17. The choke won't be too bad to get working. After that you can get on with tuning things a bit.
stlbob
St.Louis
bobby
91'
k3500 4x4 Burban'
or you could ease your pain
and put a 1407 Edelbrock carb on it
crazyman1018
Angier NC
Conner
its a rochester quadrajet not sure of the numbers and such would have to take pics and upload them what i mean was that the guy had rigged up a manual choke system when im told that most of the time they are automatic and im not sure on how the assembly is suppose to go i rebuilt most of it
crazyman1018
Angier NC
Conner
pics
crazyman1018
Angier NC
Conner
more pics
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
thatgermanguy
