Carb Bog
John81287
Mchenry,IL
V20
Hey guys had my neighbor rebuild my edelbrock 1405 and add the electric choke to it. I know it has 12 volts but it doesn't seen to be working. Also once the truck is warm it idles nicely. Adjusted the accelerator pump to eliminate the acceleration stumble. However it bogs terribly in gear now. Won't do over about 15 mph and that at 1500rpm to keep it there. Any thoughts/ suggestions?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Ensure the float is set correctly. Best way to fix problems with Eddy carbs, is to replace them with Holley, Demon, Or Quadrajet.
bigcountryguy19
Sealy texas
josh
6.2 diesel
I agree, well besides the quadrajet lol
hirschdalechevy
norcal
rich
k-30
Could'nt agree more^^^^^^^^^^^^^^^^^^^^
John81287
Mchenry,IL
V20
Really was hoping that wouldn't be the answer I got. Any suggestions? Anybody got a used one in good condition with electric choke I might be able to buy?
350runner
tx
Ceasar
Qjet all day here for the street ride... Holley for the track. You'd be amazed at the night n day diff a qjet will make over a new eddy
Sent from my LG-LS980 using Tapatalk
hirschdalechevy
norcal
rich
k-30
If you want to here are some things to check on your eddie;
Float level
idle circuit , set to highest vacum reading
choke , make sure after it's warmed up the choke plate is fully open
fuel pressure , eddie's dont like any more than 5 pounds pressure
accelerator pump arm , most eddie's should be on the last hole of the three , (closest one to the intake)
I am no eddie pro but I have messed with a few.
That holley you are looking at would be ok but you might have to jet it down a bit for a stock 305 , not sure dont mess with 305's much.
I think all around a q-jet would be best but they are pricey for a quality rebuilt one and they will get the best mileage for sure.
I am not a fan of eddie carbs , but if you want to save some money I would go though the eddie and see if you can work it out.
John81287
Mchenry,IL
V20
Float level
Thanks for the input. My 305 is not stock it's bored 30 over and got an aftermarket cam. I have the specs at home so we can get more technical later if needed. I just have never really trusted the eddy I think I might be better off just 86'n it. Maybe sell it on eBay.
Jims86
Patterson,Ca
5.7 TBI
That 600 will be perfect for a 305, considering all the Qjets were a minimum of 750.
Jims86
Patterson,Ca
5.7 TBI
John, I forgot....do you have a 700r4, or TH350?
John81287
Mchenry,IL
V20
Th400 actually
John81287
Mchenry,IL
V20
I'm really not sure how it happened but it's a 400 for sure
Boone83K10
Boone, NC
Benjamin
Is your modulator hooked up on the trans? Sounds just like that other guy who was having serious bog in gear.
John81287
Mchenry,IL
V20
I will have to double check. That should be the big vac line off the rear of the carb if I remember correctly right?
ben_swager
