- Jan 23, 2016
- Mississippi
- Jesse
- V1500 Jimmy
I've noticed a few issues with the evap system that I worry are affecting economy/performance. I fueled today, and when I opened the cap it hissed like opening a soda, and I could very audibly hear the tank popping like it was expanding. Sometimes when I fuel the pump shuts off prematurely multiple times and sometimes it fuels perfectly. Sometimes it'll run a little off, and when it does this, I can usually smell fuel vapors near the tank and near the canister. No fuel leaks of any kind and no vacuum leaks. These issues have been gradually getting worse, and it wasn't doing it a few months ago. I don't understand why the evaporative emissions is so complicated on this vehicle. It's got the canister, the purge/control valve (Rochester Products 17085891), two separate check valves, and three lines that go to the carb from the control valve. If I could get rid of these little check valves, I would for the sake of simplification. I haven't tested the canister for blockage yet, but the filter is fairly new. The only other thing that I can think of is it needs a new purge valve, but I'd like to know if those extra little things can go. If anyone has any suggestions, please offer them up. I don't think the fuel cap is necessarily an issue at the moment because it'll shut off when fueling, but maybe there're multiple problems.
