AaronW
- Mar 24, 2021
- MT
- Aaron
- V3500
Everyone:
So after fighting with my window felt for over a week now, it looks to me as though I just need to pull my vent windows, put the felt channel in, and then reinstall. I've looked through youtube, watched the Brothers video on vent window removal, but I still can't get it out. The video shows three screws holding it in, I only have two, locations marked with tape. Anyone know what I'm missing here, as well as how to loosen the main window, to slide it back a little bit? I thought that might give me some more room.
Next, I'm stuck on my rear doors, too. You can see (sort of) that I got the felt all the way down the rear channel, since there's a hole in the door where you can get some needlenose in there to pull down. However, I'm stuck, at the front of the rear doors. Can I loosen the main window and/or pull out the small window? If so, where are the bolts for the main window, so I can I do that? I've read everything I can find, on lubing up the felt so you don't have to do this, but have had zero luck, so far.
Aaron
Aaron
