Mattchu60
- Jul 25, 2012
- Iowa
- Matt
- k10
Like the title says - I am tying to find a driveline vibration in my truck - its driving me nuts.
Here is what I did so far:
- balanced all four wheels
- New U-joints
- Removed front driveshaft and just drove in 2H
None of this helped - around 68-73mph I get a funky vibration - it starts off smooth and goes to medium vibration and back to smooth in about 2-3 seconds and repeats. I thought it may be the front shaft turning on its own, its not.
I should state - I installed a 14 bolt rear end recently along with new wheels/tires. Got the conversation joint on the rear of the shaft as well. My thought is that one of the new u-joints is causing the shake, but they seem tight.
Can I take the rear shaft out and drive this thing down the road using the front wheels or is that a very bad idea? I know there is a seal where the slip joint goes into the transfer case and oil runs out this sometimes when the shaft is removed, I can imagine the amount of fluid that may fly out if there is no shaft there to "plug" the hole
- New U-joints
