Cable Tie vendor?
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Can anyone provide a vendor for these style 3/8 cable ties to frame? Thanks!
randy and Easton
randy and Easton
Auto store. how many do you need and do you want new ones specifically?
I also see google references to
"GM Wire Loom Routing Clip"​
Are these for your wiring to the rear ? The diameter I assume is the closed ID of the clip since it would be intended to be holding a section of loomed wiring on its way to where it goes
fast 99
Spokane, Washington
NAPA They are kind of expensive in single or small quantities. If there is a local Pick and Pull take a sample and get a hand full for a couple dollars.
Randy and Easton
Randy
C-10 LWB
Yes wiring for the rear lights and the looms for headlights/horn up front as well. Need 10 give or take. Thanks Taylor for the brothers info.. I did not look there, been kinda sour on them of late with some poor quality items that I had to send back.
If you go into the auto store with your harness(I assume you have it off the truck) you can get the clips from Autozone, NAPA, Oreillies, Advanced, etc. The plastic clips are usually help section or sold in small bundles.
They can be found on line, of course. Aslo, if you were REALLY looking for OE I can go pluck 10 crusty and brittle ones off my tail light harnesses and stuff for you, but I assure you they wont play nice if you ever have to remove them(brittle)
I say take ytour harness so you dont have to guess on the size you just find the ones that snap nicely around it :)
or you can take yours to compare as well
Randy and Easton
Randy
C-10 LWB
Taylor, No all good. Went by my O’reilly’s and they had nothing never checked Auto Zone. Ill snatch a few somewhere, not pressing. Just cleaning up loose ends while he finishes getting it back together. I have much bigger fish to fry.. Darn power windows!! Have great weekend.
Randy and Easton
Randy and Easton
I know my local autozone has a section dedicated to plastic clips, retainers, and it may be on a spinning display kinda like they also use for bolts and hardware
dabsRus420
