Cab Corner, Rocker Joint Question
DanMcG
Central NY
k10 k10
Can anyone tell me if the joint in the circle was attached in any way or just seam sealed?
These are aftermarket patches and the way they're stamped they'll only be getting seam sealer, but was thinking they could have been spot welded from the back side, maybe
yevgenievich
Place
Name
Year
Model
Size
Should be spot welded where they come together with the folded over part.
DanMcG
Central NY
k10 k10
Which part folds over, the corner? Mine doesn't but there's enough material to maybe make it work.
Edit; or are you talking about the very bottom flange/ lip?
thanks
Joshua Keith
Memphis
Joshua
i don’t know the correct answer here, but I ended up seam sealing mine.
yevgenievich
Place
Name
Year
Model
Size
On the backside there should be some overlap to weld to. On the front seam sealer
I've only ever seam sealed that area where they overlap.
DanMcG
Central NY
k10 k10
Thanks Guys! I just wanted to make sure I wasn't missing something.
legopnuematic
Licensed Junk Dealer
MO
Spencer
A swipe of seam sealer from the factory, but on my 79 I Welded that seam Solid and then ground it flush.
kodyg86
