C&C swap from 14bolt rear headaches
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Here we go for round two swing and a misssss dissassembled everything from dually c&c plan was this morning to take srw hub from 14ff off the truck and put it on the drw drum, takeoff the backing plate plate with brakes from drw cc and swap that over to the srw 14ff axle on the truck then add the dually drum with the with the srw hub.. Here is the problemo....
2nd pic you see the srw14ff hub will not accept the wheel spacer becuase of the1/4 in lip and is 2 1/16 wide need it to be at least 2 1/2 wide for the wheel, then spacer then outter wheel to slap together on it. At least im learning and understanding with getting my hands on everything.
3rd pic is with the wheel spacer not mounting flush to the wms
Sent from my LGMP260 using Tapatalk
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Forgot the pic
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Im goin to try o find a set of k30 srw hubs
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
So i finally said screw it im goin to move the perch inside 1 1/2" made my own new perch
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Question for setting pinion angle. The whole Idea is to get the pinions matched up parallel for correct operating angle? I was goin to go off the what's on the truck but checking it today I found that it 6deg difference from the slip yoke on the 205 and the pinion on the diff.
Driving pinion 3 degree
Driveshaft 18 degree
Driven pinion 9 degree
When I center the dually under the truck set the springs on the perch can I set the pinion angle at 3 deg and get a CV driveshaft ( has a single u joint shaft in now) built or missin a step?
Sent from my QTASUN1 using Tapatalk
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
A while later with all my fingers and toes still attached. she is almost ready to make some dollhairs
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Dually swap
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Veiw from the rear
Awesome! I like the spring hangers too, all sorts of adjustability.
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Last steps to a money maker fellas!! Almoat there!
Heavychevy27
Central Pennsylvania
Heath
k20/30
Just wanted to stop by and say THANK YOU. I have been searching high and low for a way to make this work. I was unaware that the C&C axle width was thinner than the regular. I spent 300 on the axle and 6 wheels and tires thinking I would only need to move the perches. I rebuilt the axle, bought the perches, and replaced a whole bunch of parts before I realized the springs wouldn't fit inside the hubs. You've confirmed for me that this is doable and provided me with a template to do so. Very much appreciated. One question. Could you possibly give us a little more detail on your shock mounts?
Heavychevy27
Heath
k20/30
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You will attract a lot attention AND work with this setup. Great job.
You remind me of my own work, detail and picking up a body line here or there designing a deck goes a loooong way to making something
custom look just right.
At the end of the day, it's not really that much more work than a square box for a deck.
And thanks for the build thread and all the photos!
jlyon1006
