Bvllsh!t on craigslist.
CSFJ
100bucks for tach cluster that's not bad is it?
From what I've seen some sell for, no. But then I guess it all matters on how bad you want/need one.
ajd89
Central Michigan
andrew
LOL well you know it's a want I texted him he still has it said 80 bucks if the wife asks though it's definitely a need
CSFJ
I'd consider grabbing it myself, but I guess it's not a big enough priority because I haven't bothered to look up what's different between the '73 to '80 versus the '81 and up clusters.
ajd89
Central Michigan
andrew
Well get it man. I've got to figure out when I can make it over there anyways. I know the font is different. Not sure about the wiring side though. I'm sure it can be made to work with the 81 and up
CSFJ
like I said, just not a priority.
vkh
Western Montana
Var
C2500
My trucks an 81 and an earlier tach cluster plugged right in, just had to add power, ground, and signal for the tach. I think the two main things to consider are electric vs mechanical speedo and amp vs volt gauge when swapping clusters.
CSFJ
The speed would probably be the easiest of the conversion, I'm going to use a np205 after the rebuild. The biggest question I've had, is where do you pick up a tach signal on a diesel? I know it's possible, all the old semi truck had them, I've just never looked into it yet.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Older VW diesels got their tach signal from the alternator.
CSFJ
I was wondering if that's were it was pulled from. not much else under there to get a electrical signal from. Only other option would have been a driven cable, like the old points cars ran.
89BurbanGuy
