Bvllsh!t on craigslist.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It cures cancer though!!!
So does not knowing about it. I don’t go to the doctors, unless I’m in an ambulance. Ignorance is bliss when it comes to my health.
Big Chip
Michigan
Kevin
C35
Fair enough.
Big Chip
Michigan
Kevin
C35
I’m to ornery to croak. When I get to be @RustyPile age im gonna be cruising around on my scooter running into people and blaming them for being there.
I’ll race you when that time comes!
ajd89
Central Michigan
andrew
https://grandrapids.craigslist.org/pts/d/rebuilt-456-gm-14-bolt-rear/6451199995.html. What Do you guys think about this? I know it's expensive to have axle work done. Hard to find a front with the 4.56s. He said he don't want to split but he would take 350 for the front axle. Thing that sucks is no axle shafts backing plates spindle or anything else I've got another 10 bolt but it's 6 lug so I'm still stuck finding the some of the parts to convert it but id be closer....
CSFJ
What truck are you putting these under? If it's a crew or 1 ton,it should be a dana 60 under it. If it's a dually, the outer knuckles won't work with a 10 bolt.
ajd89
Central Michigan
andrew
CC 1 ton I know it should probably have a dana 60 i cant afford one lol. I'm not planing on getting to crazy with it so hoping a 10bolt will hold up. The outer knuckles? Like the width is different???
CSFJ
is this a dually truck or srw?
CSFJ
The dually knuckles are different from the srw ones. They have a large hub extension to allow use of the dually wheels. I don't believe there is anything available that will bolt to the 10 bolt knuckles that will allow those wheels to be used.
ajd89
Central Michigan
andrew
Yeah after you started asking that I was wondering if thats where you were going darn it! I wonder how much wider it would make it? some fender flares fix it? Get dually rims made with a smaller offset? This really throws a wrench in the plan lol. Thank you for pointing this out glad I asked b4 I buy something that's not gonna work.
Ed Ball
